1 - 9 of 9 Posts
What do you guy think of this? It seems popular in clublexus for Lexus.
Xtreme HID 4300k Philips Xenon HID Conversion Kits
Below are conversation of KBcarstuff
Hi,
The Xtreme kit will come with a relay harness to power the ballasts directly from the battery however the Xtreme ballasts are true low draw ballasts (only 4.5A on a cold start) meaning that you should be able to power them directly from the OEM wiring.
Steve
Tel: 1.877.522.2701
On 2012-01-04, at 7:05 PM, Kevin Yuen wrote:
Sounds good, how do you think the installation like in CT200h?
I had to connect the ground to battery (Honda Pilot) for another brand which use Philips bulb and ballast, is it required from this Xtreme ballasts?
Sent: Wednesday, January 04, 2012 3:59 PM
To: Kevin Yuen
Subject: Re: HID for 2012 Lexus CT200h
Hi,
Xtreme ballasts are super low draw. I have them installed in my Toyota 4 runer (auto) and no issues.
Steve
On 2012-01-04, at 6:52 PM, Kevin Yuen wrote:
Hi Steve,
Do you have if it works on Auto mode? Have you heard about mis-firing problem on CT200h? People having a lot of problem using different brand when the headlights are at Auto mode.
Thanks,
Kevin
Sent: Wednesday, January 04, 2012 3:46 PM
To: Kevin Yuen
We only carry 35W kits.
Tel: 1.877.522.2701
On 2012-01-04, at 6:24 PM, Kevin Yuen wrote:
Is it a 35w or 55w?
Sent: Wednesday, January 04, 2012 3:15 PM
To: Kevin Yuen
Hi,
You would need the H11 fitment meaning that you would need to get item number XT-4k-h11p
Regards,
Steve
Tel: 1.877.522.2701
On 2012-01-04, at 4:54 PM, Kevin Yuen wrote:
Hi,
My friend bought a HID kit for his 2007 Lexus IS and gave me a link since I’m interested to purchase one for my 2012 Lexus CT200h. Do you have any recommendation?
thanks,
Kevin
The relay is not required with any 35W HID kit. HID lights pull full rated current at start-up to arc the HID lights then once arced the ballast backs off the current. 35W uses 2.92 amperes at startup ( 35/12). Even 55 watt only uses 4.58 amperes. The OEM lights are on a 40 ampere circuit. Just FYI under the fuse cover in the engine fuse box there is a direct connect to the 12 volt battery, should you ever need it.
I see the positive connection for jumping the car under the hood but can't figure a way to clam the fork connection to it...please help
1 - 9 of 9 Posts
