1 - 15 of 15 Posts
Changed my transmission fluid today and I noticed that the front Jack location got crushed. Does this happen to anyone else? Should I be concerned?
Looks like might've hit something or bottomed out on a speed bump? Can't quite tell from the photo.
ouch...you must of hit something solid.
BTW...welcome to the forum.
In a previous car (2002 WRX), I ran over a large rock and somehow managed to kick it up while it was under the car. It caused a 3 inch protrusion to at the rear passenger floor.
Seems like you'd remember something like this...
You're right. Somehow i missed that fact. Well that's not good...does the jack still fit in that spot?
Discussion Starter #8
Thanks for the replies. It was definitely caused by the jack. As far as i can tell that Jack location is reinforced and there is a second layer of metal under the layer we can easily see. Everything seems fine and I am not really worried about it (although I may paint the scratched metal to help prevent any future rust).
I was just curious what others who work on their own CT by lifting with a floor jack look like. How do your Jack locations look after lifting the car?
From you picture it looks like you had the floor jack positioned correctly; doesn't appear this should not have happened.
Wasn't it still under warranty and why are you changing tranny fluid for a 2013 car?
What does the top of your jack look like? Usually (including both of my floor jacks) there is a 4 or 5 inch diameter dished metal piece that meets the car. There are Urethane insulation pieces available to fit on these to prevent scratching the underside of your car. My floor jack completely surrounds that part of the car and could not dent it. Your dent appears to have been caused by a jack with a much smaller head area that contacted the car. Or you actually ran over something.
I've used the front and rear jacking pads a lot on my 2011 with 90k miles and they still look like new. Normal jacking should not damage the pad like that.
Hi guys, I just noticed that I have the same type of crush on the front jack location on my ct200h.
Is this normal? What type of jack should one use in order to avoid it?
1 - 15 of 15 Posts
