Hey ya'll.
Sorry, kinda been under the radar for a little bit. Still waiting on mods, I may be changing suppliers for the lip kit and suspension due to response time and delivery issues.
Here's a fun little write-up on how to access the Service Menu in our CTs with navigation and Remote Touch remotes. The Service Menu provides some good information in terms of HD checks, system checks, and also provides some information on firmware, etc.
Disclaimer: I hold no responsibility for any damage or injury this write up may cause. Thank you.
Step ONE:
Make sure your headlights are set to Auto or OFF. Make sure your car is off.
Step TWO:
With the car off and foot OFF the brake pedal, press the power button once to enter ACC mode. The power button should glow amber.
Step THREE:
Wait for the NAV screen to lift up and for the Lexus logo and Lexus Enform splash screens to complete.
Step FOUR:
Go to your Remote Touch controller and press the Menu button once. Your START screen should show up.
Step FIVE:
Press and HOLD the Menu button. At the same time, cycle your headlights from ON to off/auto FOUR times in rapid succession.
The NAV screen will then enter the service menu.
That's it! Enjoy! Most diagnostics are pretty fast. To clear any error codes, just press and HOLD the CLR CODE button or CLR MEMORY until the screen refreshes.
I had a few errors on mine, but after I cleared the codes, they haven't come back.
One of my error codes was from way back in March! You can also see the version of your firmware too in case of troubleshooting, etc. You can also check to see whether your microphone for the voice recognition/bluetooth systems are working.
NOTE: The HDD CHECK function will take up to 5-10 minutes. So don't freak out if it seems like it's taking a while.
UNDER HANDSFREE VOLUME SETTING, there's an option to adjust your RECEIVE audio level. Does anyone know what this could be for?
Also, I just noticed the Camera Settings button is greyed out. I'm gonna play around. Hopefully, there will be a way to bring back the parking LINES onto the reverse camera screen!!!!!
Good luck.
Step ONE:
Step TWO:
Step THREE:
Step FOUR:
Step FIVE:
Good luck.
