Im looking at Drag DR-34 235/40/18 +45 8.5 width. They weight 22 lb each. Anybody got this setup? Do they fit? Also, will the 235 throw the mpg by alot? Our stock tires are 215, that's why I'm worried about the 235. Thanks for your response!
Yes your MPG will be affected. And based on the offset you should be fine since its pretty much the OEM offset if I remember correctly. You may want to go with hubcentric spacers to push them out if you are looking for a flush look. I went with 225 with the idea of helping minimize the negative affect on gas but I dont think it would make that huge of a difference personally, unless you are able to get low rolling resistance tires which is what OEM currently is and perhaps that would help you maintain a minimal decrease in MPG.
