Hi,
My 25K miles maintenance is due in few days. And the manual says check all fluids level. And seems like the two pink container (guessing it's a coolant) and also the brake fluid requires to refill.
So, could anyone please let me know if I need to refill it on this maint. and which brand should I be using?
Thanks!!
Moderator
If your two coolant reservoirs and brake reservoir are low (with the car off) you can top them off to the fill line.
I'd highly recommend using OEM Toyota fluids, especially if you're only topping off.
If you wanna use RedLine or Royal Purple or whatever, that's your call, but you're gonna want to drain all the OEM stuff before replacing it.
