Hey all, I'm pretty happy with my Premium Audio, but as always, want to tinker and tweak it a bit.
I'm not a fan of the factory boosted bass at low volumes and the bass reduction at higher volume.
I plan to remedy this issue with an Audio control LC2i.
I also wish there was a bit more bass to play with, nothing too crazy to offset the remainder factory speakers.
My plan of approach is powering the factory woofer with an aftermarket 150-250 watt amp. With experience in the past, clean power goes a long way, so I'm hoping this will do the trick.
Does anyone know the factory subwoofer wattage and ohm rating and size?
If this fails, I will add an aftermarket subwoofer into the factory enclosure. I don't want to take away the trunk space and don't want to deal with a box.
I swapped out the factory sub with a Hertz slim 8' and added a pioneer 300w class d amp. The slim sub fit in the factory location with a bit of modification. I changed out the fronts dash tweeters with Rockfords and the rears with infinity 6032cf. It sounds so much better and I didn't need to change out the class a/b amp for the door speakers. Highly recommend keeping the fronts stock. Hope this helps.
Where did you pull the wires from to do the line converter to do the RCAs? I pulled off the sub and for whatever reason ( i think unclean signal ) the sub distorts. I'm wondering if i'm using an amplified signal, then amplifying it again...
Any help would be great!!
