If and when there's an update people in the regions should chip in and buy one and burn it and distribute it. Just my $0.02You buy a new disc from the dealer at an outrageous price, especially considering that it is probably out of date before the dealer gets it. In other words, don't bother. That is just my opinion. Most major roads don't change all that much and I can't figure out what the upgrades are, because some obvious ones aren't done.
If I am correct it won't help you any because you still have to take the disc or usb to the dealer for install. I believe this is not a DIY project.If and when there's an update people in the regions should chip in and buy one and burn it and distribute it. Just my $0.02
I have built-in navigation on my CT that's too expensive to upgrade with Lexus maps. However, my portable Garmin has lifetime maps -- and was far cheaper, too!If I am correct it won't help you any because you still have to take the disc or usb to the dealer for install. I believe this is not a DIY project.
Plus they most likely not install a non original Lexus item.
There goes that idea! LolIf I am correct it won't help you any because you still have to take the disc or usb to the dealer for install. I believe this is not a DIY project.
I also have an older Nuvi with the lifetime maps.. I check at home before I go on the road to verify a new destination.I have built-in navigation on my CT that's too expensive to upgrade with Lexus maps. However, my portable Garmin has lifetime maps -- and was far cheaper, too!My new Infiniti updates the maps for the life of the car.
