Just wondering has anyone installed those ebay type amber leds as turning lights ?
Sent from my GT-N7105 using AutoGuide.Com Free App
That post seems to be on changing yellow bulbs to chrome type oem bulbs.
Was trying to search for posts on any successful bulb to led conversion without requiring resistors.
Maybe using a new relay etc which is on ebay. Perhaps a new relay is not required, not sure so hoping to find out if someone has tried.
Modern cars do not use turn signal relays. The flash is ECU controlled and the signal sound is ECU generated as well. You either need resistors or the "canbus error free" LED bulbs that have resistors built into them to avoid hyperflash. The latter option is quit pricey ($40-60 per pair).
The flasher assembly listed is not necessarily a relay. The eBay listings are for older cars.
