Found this on Prius chat where there are many discussions about when to do it. The general rule seems to do it at 30,000 miles then every 60,000 after that. It is really simple and if you can change oil you can change the ATF in your CT. It only holds 3.5 - 4 quarts and is a simple drain and fill until fluid comes out the fill hole. You need Toyota WS ATF.
Transaxle Fluid Drain & Fill (DIY Easy as 1-2-3) | PriusChat
Prius C Tranmission/Transaxle/HSD Oil Change | PriusChat
