1 - 8 of 8 Posts
hello friends i need your advice my car starts only with Emergency Start Function, no dtc codes the 12v battery is brand new. i checked key fob battery as well with multimeter ant voltage is 2.84v. any advice?
Discussion Starter · #7 ·
it the car does not start, you push one time on start button without touch brakes and second time you are pushing and holding the button about 20 seconds. it should start.
i changed tha key battery but without result. when i am pressing power button for about 15 seconds the car is starting. from where to start find a problem?
When you changed the Fob battery, did you use a new, out of the packet battery (CR1632 if I remember right). I had sort of similar issues and tested my batteries 3 times--always tested good. One of my 2 testers was supposedly NIST traceable, meaning it was supposed to be a good tester. I bought new batteries, replaced one in the Fob, and the problem was solved. For $5, I'd suggest you again replace the batteries.
1 - 8 of 8 Posts
