Has anyone tested the Hybrid battery to see how healthy it is? Did you use Techstream or the Dr Prius app? The Dr Prius option looks much better to me since you can use it while driving and see how each battery is performing under various loads and states.
I live on a mountain top and frequently drive with a 500 lb -ish passenger/cargo load, I only get in the low 30 mpg's no matter what I do, but I have a feeling that is normal due to the circumstances. No HV battery errors, but I would like to verify the HV battery anyway.
I ordered a $10 wireless connector recommended by DR Prius and will be trying it.
If I should find a weak cell, does this car use the exact cells as the Prius of the same years? Are they the same from 2011-2017?
I figure these cars are getting old enough now that many of you have had problems and dealt with them.
Thanks
Thanks
