1 - 17 of 17 Posts
Has anyone installed a set of Tanabe NF210 springs yet in the US?
Here's a link:
Lexus 2011 CT200H (ZWA10L) Tanabe NF210 Lowering Springs (TNF165)|Tanabe NF210 Springs|Tanabe JDM Suspension
They look like exactly what I'm looking for. Nice 1.5" drop all around with very soft / OEM like ride quality (I have my z51 vette for handling / performance)
I just want a lower ride height for my 20k miles a year I will be putting on the CT200h.
Just wanted to confirm fitment / quality issues with these springs before I order a set.
Discussion Starter · #2 ·
Btw Road Magnet springs are 260/300 in/lb spring rates F/R
Tanabe are 2.2/4.7 kg/mm F/R or 123/263 in/lb F/R.
I would like the softer of the two for comfort purposes.
I just installed the Tanabe NF210 springs. The install was easy using my Milwaukee impact wrench alone with spring compressors for the front struts. The ride is a tad firmer than stock. The handling is amazing with flat cornering. The fist sized fender gap up front was cut in half. The fender gap in the rear was eliminated. The ride / handling balance is excellent. I highly recommend these springs.
Hi ! What are Megan coil overs? How much are they? Where can I get them?
They will be out soon as I got them custom from them. Usually around 950+. These are adjustable shocks and ride height. They will also have the spring set which is on the softer side and fixed height cause some of the lowering springs the rear is lower than the front.
1 - 17 of 17 Posts
