video is private
Fixed it! Thank you!video is private
It does not when moving, however, the sound happens on the smooth surface like parking lot as well too.Does that sound happen when moving? What's it sound like from the outside? It almost reminds me of just tires rubbing on the ground as they turn.
It's electrical power steering
I tried to search on the problem on the forum, but haven't had any luck...
Checked the power steering fluid level, it was good.
Anyone have any idea what could be the problem?
Raise your front of the ct and check the noise?
**** LOL I guess I checked the radiator fluid. The pink fluid.It's electrical power steering
No fluid.
If no noise
Raise front left size and check
Raise front right side and check
Hi ,check if the rubber cover of the lower suspension ball joint is leaking black grease ,also check the same with steering ball joints.Did you find the cause? I am having the exact same sound. Just bought a used lexus from an official dealership, but the dealer is quite far nd would like to save the trip to the dealership.
thanks
