1 - 11 of 11 Posts
I've got the black leather interior (don't know if that contributes to the problem) but my car has the most irritating squeaks. They come from behind the driver's seat, sound like little mice, when going over slightly bumpy roads, which is my entire drive down 3rd Street going from Beverly Hills to Downtown LA. It's got to be something rubbing as a result of the body moving up and down, just haven't figured out what it is.
Going to take it in to the dealer to get checked out when I have time (I'm guessing that they won't be able to reproduce the noise), but was wondering if anyone else had them, knows where they are coming from, knows how to get rid of them.
I had squeaks from the stitched trim along both sides of the center stack. Was noticeable when the cabin was warm to hot (i.e. out in the sun). Would creak, squeak, pop on the slightest bump. Lexus did a good job and fixed the problem the other day - they tightened some screws/clips and added more padding/felt where the plastic was in contact.
I've noticed squeeks/sounds coming from the seat belt adjuster on the passenger side B pillar, especially when I have no passenger.
I had this as well as a rattle coming from the dash, both fixed by Lexus. However, I still sometimes get the rattle from the seat belt which is caused by the buckle sitting on the top of the seat when it has been taken off and allowed to retract, I just reach over and push the buckle down flat, if that makes sense.
Discussion Starter · #6 ·
Took my ride in yesterday for its complimentary 1000 mile check up (was immediately told that I don't get one, it is at 5000. Well, if that is the case, why the hell did my Nav display tell me I get one at 1000 at Jim Falk Lexus 15X? But I digress), coolant replacement, and most importantly, the fixing of my squeaks. The service rep was able to determine that the sound was suspension related and wound up tightening the a nut or a bolt connecting the stabilizer and, voila, the squeak is gone! I've only driven one way to work on my squeakless car, but the fix makes a world of difference. Instead of feeling like driving a tarted up Toyota, it finally feels like I'm driving a Lexus.
Starting to get some rattles now as well, probably due to the car being lowered and 18" tires. I hope the winter months aren't too bad once it's colder out, as that's usually when you get more frequent rattles. :(
Let me squeak up
No worries with the CT, but on some occasions I have used a well-directed, short spray of straight silicone, wiping off all excess. I don't know if it is recommended for use on leather and trim, so you are on your own there. I've had no problems, but it has cured a few trim squeaks and creaks.
My CT is as solid as a bank vault... no squeaks at all.
1 - 11 of 11 Posts
