I just got my 2011 ct200h and did my first oil change. Unfortunately I couldn't remove the special tool that goes on the oil filter cap. I left it on there. Should I be concerned?
I know what you mean, mines was a little stuck so I used a hammer to lightly tap it in different directions to remove it. If you leave it on there it might loosen and come off from the road bumps. Despite the underneath cover being there, not sure it could contain the loose tool if it does come off.
I'm more concern with the weight of it on there stripping the threads. But then again when oil flows through it, it's becomes heavier so it's gotta be somewhat beefy.
