Hello,
I want to replace the spark plugs and direct ignition coils on my CT. I would like to replace them with a higher performance, possibly racing like, plugs and ignition coils. Who do you recommend?
I'd stick with OEM specs. Its a Prius after all. The most powerful ignition is one that does a complete burn, which is also the most fuel efficient. The engineers had fuel efficiency in mind when spacing the coils and plugs. Unless you did things to drastically change the engine, avoid it. Cold air intake doesn't count.
