Hey, just wanted to share some picks of the caliper covers and rimblades installed on my white Ct200h.
I also changed my interior lights to blue leds, puddle lights also blue and added some blue leds to the footwell. I added a blue led strip attached to the underside of the cargo cover with a quick disconnect plug in case I need to remove it for larger cargo.
My Ct. came with the illuminated door sills so I decided to keep the blue theme on the car. A friend of mine that does leds on boats and motorcycles provided all the led strips. He even game me four 4' led strips which I installed under the car and tapped into the door sills. I only wanted them on when I open the door. Come to find out, the door sill stay illuminated when the car is on and on Park enabled. Once you shift to drive or reverse they turn off. So the leds will be on as long as the car is parked or the door is open. Other then that it shuts off.
I also changed all my speakers (base system) to the low end kickers DSC and CS series. I added an Alpine Power Pack (4 channel amp 45watts per channel) behind the stock HU. I then tapped to the rear speaker wires (after the amp) and ran the cables to the back where I connected a LOC to the speaker wires and ran RCA cables to a Rockford 300 watts 12" powered sub. It comes with a remote that I installed on the left side of the radio.
Other mods are tinted windows, pedal covers and some small Christian decals cause Im christian and love God. I ordered a license frame cover that is blue with the lexus emblem.
I will post more pics later when is dark outside so you can see the lights.
Darren.
Discussion Starter · #2 ·
Here is a few more pics. One when you unlock and the puddle lights turn on. One the vehicle in park mode. Two of the trunk. One of the pedals and one with the location of the control for the sub.
Darren
