Hi, I see remote engine starters available from Lexus and on Ebay. I have a premium, but otherwise basic Ct. IS the receiver that takes the signal already installed onaboard? (ie, what else do I need to buy in addition to the remote key?)
Good question, I doubt it though. Can you share the ebay link so we can read the description? It should tell you what it comes with, maybe that will help.Hi, I see remote engine starters available from Lexus and on Ebay. I have a premium, but otherwise basic Ct. IS the receiver that takes the signal already installed onaboard? (ie, what else do I need to buy in addition to the remote key?)
Lexus Remote Engine Start 2011-2012 Lexus CT200h | eBayGood question, I doubt it though. Can you share the ebay link so we can read the description? It should tell you what it comes with, maybe that will help.
it's a module and works with the keys that came with the carThis may be a stupid question but do you only need the special remote to have the remote start ability or is there a module that has to be installed in the vehicle? I have a 2012 CT with the non-nav package.
Any car that i've owned in the past have had to have a module installed into the vehicles electrical system. If all you need is the remote to ( and possible reprogramming) start the vehicle, almost seems to easy.
Am i missing something?
Thanks
I'm interested in the cost to activate as well. The installation procedure itself looks fairly easy.Do you know how much they charge to activate the module? I didn't get my ct with the remote starter originally.
They charged me $500 flat for the remote start and installation.Do you know how much they charge to activate the module? I didn't get my ct with the remote starter originally.
WOW pricy! Is it something you can do somewhere other than the dealership?They charged me $500 flat for the remote start and installation.
6.Registration
a. Open the Hood.
b. Temporarily reconnect the
Negative Battery Cable. Do not touch thePositive Terminal.
c. Locate the 1P RES Diagnostic Connectors in the Passenger’s Side Cowl Area and connect them.
Note: Once connected you will have 10 minutes to complete this section, steps d–aa.
d. Close all doors.
e. Place the Vehicle in Park (P) or Neutral (N) position.
f. Cycle the “ENGINE START STOP” Button from OFF to
Note: One cycle consists of:
OFF->Accessory->ON
This is equivalent to pressing the “ENGINE START STOP” Button 14 times.
Look: For the Hazard Lights to Flash Once.
g. Start the Engine.
h. After 10 seconds stop the Engine
i. Connect the Techstream Notebook to the Vehicle’s Diagnostic Port.
j. With the Smart Key in your possession, press the “ENGINE START STOP” Button twice to select the Ignition “ON” position.
k. Start the TIS Techstream Application by clicking on the shortcut located on the Desktop.
l. Click “Connect to Vehicle.”
m. Confirm that the information displayed on the Vehicle Connection Wizard is correct for the vehicle. If not verify that the Techstream is properly connected.
n. Select “Others”
o. Click “Next.”
p. Select “Smart Access.”
q. Click ---> (arrow).
r. Click on “Utility.”
s. Select “ECU Communication ID Registration.”
t. Click ---> (arrow).
u. Click “Next>.
v. Select “Remote Engine Starter.”
w. Click “Next>.”
CONFIRM: that the ECU Communication ID was completed successfully.
x. Click “Exit.
y. Click "close".
z. Exit the vehicle.
aa. Close the Hood.
ab. Look for the Hazards to flash twice.
