I used a 12 v power outlet extension connected it to the original power outlet for my camera. Two days ago, I noticed that there is no power supply, upon checking the fuse, I noticed that the fuse under the instrumental panel was blown. I replaced it with a spare 15 A fuse. But, there still no power supply to the power outlet. The rest of the electric supply seems to function normally. How to rectify this problem? Thank you
There are 2 15A fuses one above the other. One is for the usb outlet and the other is the aux. Are you sure you replaced the right one?
Yes, I’m sure I changed the correct 15A fuse, which is located on the third position.
