Was looking at some prius 10 parts and came across Tanabe Sustec underbrace front for Prius 10 part#tub153f compatible with Ct200h 11-13
Anyone else know if there are more compatible parts ? Any TRD Prius parts which are suitable ?
It already has 2 lateral dampers.Would the brace make a difference in the CT or are they 2 different functions?? If, it does, I'm all for installing it.
Discussion Starter #4
Check out priuschat for some discussion on the tanabe tub153f. The Prius L shaped brace were upgraded to a triangle brace in 2012. Ct200h seems to be using a L brace like in the 2010 Prius. There are pictures in the Tanabe usa site showing the CT200H brace where the tub153f mounts. Top of the L shaped brace. Possibility of installing the prius triangle brace part if mounting holes are same ?
Bobis the oil guy site has some critical views of mike500 selling his "aircraft quality" part on prius chat.
The CT200h is based on the Matrix/Corolla chassis not the Prius. It only uses the Prius engine and drivetrain. That is why it handles so much better than a Prius. I doubt the Tanabe part will fit.
