1 - 9 of 9 Posts
Curious to what volume we mostly listen to. Normally I'm around the 25 mark and will max out at 32. Curious to hear what volume others listen their music at
I'm usually in the 50 to 62 range
Depends on the source. AM is very quiet, I listen in the 30-40 range while driving. Then if I switch to FM or CD-RW/FLAC I have to drop it about 20 points to not blow my ears out on switchover. So, I'd say in the 20-30 range normally. For rompin' music while overcoming freeway speed road noise, 35 is where it's at, sometimes heading up to 40. I've dialed it up to 60 (max?) during testing, but there's been no need to go anywhere near there in real listening.
Note: None of the above takes into account the addition of the subwoofer with gain control next to the steering wheel. That's adjusted separately and should be taken into account with the above numbers.
Nothing beats your own ears with your own music though. =]
I mostly listen to FM and when not moving will be around 10-12, but when driving will go up to the teens and on the freeway around 19-20. If I am listening through BT or USB, then it is usually in the 20-25 range. I rarely use satellite, but am usually around 20-25 also.
I'm with Moon Unit
With XM I usually have it set to 25ish. If I'm on the highway with the windows cracked or the sunroof open then 32-35 seems to work okay.
I haven't really played with the other inputs since XM is free for the first three months.
Is there anyway to scroll the song title with the premium HU?
1 - 9 of 9 Posts
