Wondering if folks with backup camera has this issue with their screen in their rear view mirror? This is happening on the top right corner. All other corners are fine. Nothing is obstructing the camera so I'm sure it's the screen that's defective. Just wondering if other folks can verify if indeed its a faulty screen by checking their own backup camera screen located in the rear view mirror. People with nav system need not answer because your screen is the nav screen itself.
To help you with diagnosing a potential concern with your back up camera place a plain white sheet of paper over the back up camera and see if the right upper corner still exhibits the same blemish. If not, I would suspect a part of the hatch is appearing in the camera's view.
Took it in to Lexus. Tech verified the problem and said that the camera is catching a shadow that's causing this problem. Check out other CT's and had the same problem. Unfortunately, there's no adjustment to fix this problem
