The font damper installation is not so easy as rear.
1. Dismount the windshield wipers - just pick up the plastic cover to get to the each nut.
2. Now we need to dismount the cowl panel, pick up 2 plastic clips (1 from each side).
After that pull up the panel, there is a few plastic clips on the down side. Just push them with fingers and pull.
Then you will see the black metal plate, tightly screwed to the car body
You need to unscrew 5-6 bolts (don't remember exactly) to weaken the connection of the plate and body.
3 bolts from the left side
And 3 bolts from the right side. There will be a problem with one near the windshield wiper mechanism.
Ok, now install the front damper. Pull up the black metal plate if needed.
The nut space is too narrow (that's why we unscrew bolts from the plate).
Now pull up the plate and put the nut over...
Left side is ready.
Do the same from the right (will be little difficult than from the left side).
The result.
That's it. Now screw bolts, get back cowl plate and wipers. Then turn on the engine and go for a test ride
Hope that this "manual" will helps someone.
