1 - 9 of 9 Posts
Has anyone had problems with the odometer?
I've driven about 1500 miles and when I started the car yesterday
the odometer had 1850 miles, today when I started the car it was at
2450 miles. I'm the only driver and when I talked to the service tech said he never had a problem like that but a firmware update should fix it. Any suggestions?
Somewhere the accurate mileage data has to be stored otherwise you will be out of warranty b4 year end :>)
Did you make sure some of the readings you saw wasn't one of the trip odometer readings and not total miles?
Trip odometer shouldn't be higher than total mileage though. :eek:
So if I'm reading this correctly, are you saying your odometer is reading 950 miles more than you have actually driven?
:eek: Wow.. talking about a way to bring up the fleets fuel mileage numbers.
Congratulations, you will be the first to get 700+ miles per gallon :)
1 - 9 of 9 Posts
