Is there a way to customize the the following two features?
1. always turn on sports mode after restarted.
2. turn on LED day drive light when headlight on?
thanks.
thanks.
NO, not through normal means. :(
Someone may be able to come up with somes hacks for either or both. :confused:
Not bad ideas though. :cool:
Lexus needs a "user modification feedback" channel whereby users can send in requests to Lexus. And Lexus is required to respond one of three ways (1) NO, (2) YES - for general populace -FREE or (3) YES - special mod - xxx$ cost.
Again, two of the best would be to make navigation have an option that you can enter addresses when the car is moving "Do you accept that this could be dangerous? Yes-button, No-button. Other lesser cars have this, susch as Honda Accord. I know someone has found some solutions to this that require extensive harness unpluggin/plugging and are somewhat pricey --cheapest is $185 ARRRG :eek:
Second , allow full function of blue tooth phone why the car is moving. It is ironic, that you can use "call history" when moving but not the contacts list through the nav screen.
Peace,
MidCow3
It might be different nav system/setup in the UK but you can enter an address/postcode and scroll through the contacts when the car is moving. You can do this by using the remote touch or voice.
