Hi everyone. So I just realized that both of my headlights are out, as well as the license plate lamps. I checked all the fuses and the bulbs, and all are fine. It's the low beams only, the high beams work. Anyone have any ideas? Where is the headlamp relay? Is there a separate one, or is integrated into that nifty mega-relay in the engine bay fuse box? Help?!?!
Discussion Starter #2
When trying to troubleshoot, I noticed the DRLs don't dim when the headlight switch is turned on. They stay at full brightness no matter what position the switch is in (other than OFF). Any ideas?
So, turns out it is a known problem with the CT. Took it in to my dealer on Friday, and it is completely covered under warranty. It's the ZL1 service and was recently announced. Involves replacing the wire harness, so not an easy or quick fix. Should be ready by Wednesday, so in the meantime I have a nice IS200t...
