Hello everyone,
I just recently got my ct200h in Bangkok, Thailand and I need some help switching some functions of this car. My ct200h is a UK spec SE-L Premier. Can anyone give me some suggestions on how to change the ODOMETER from Mile to Kilometer? Thanks a lot
I believe you can just cycle through the Display screens by hitting the Display button on your steering wheel. Once you get to the 'Settings' page (make sure the vehicle is stopped) you can HOLD DOWN on the Display button and itll take you into the settings where you can change that.
Hi up1234 - if it's not in the DISP customisation settings as Jedi767 suggests, try in the customisation area in the Nav display. Think that gives the km/mile option.
Change Unit Displayed On The Screen
Hello everyone,
Press the “DISP” switch to display the SETTING screen while the vehicle is stopped, and then press and hold the “DISP” switch to display the customize mode screen.
Press the “DISP” switch and select “VEHICLE” and press and hold the “DISP” switch.
Scroll down to "Instrument cluster" and select "UNITS" to change value.
Good luck.
I''m in the UK. I'm at work now but I remember reading in the manual exactly what 11LFCH says.
What does your dealer say?
