Hi!
So, Darkside gave some fantastic information relating to setting the memory seats based on which key is used to unlock the car - you unlocking the door will bring the seat to your preferred driving position, and 2nd key will do the same for the 2nd person!
Posted below are Darkside's instructions! Thanks again! Hope this helps someone else too!
Originally Posted by darkride
Yes here is a link if my instructions aren't good enough See Pg. 81 (it has pictures
Manual
1. Enter vehicle with desired key only.
2. Make sure car is Off
3. Once seat is in desired position, hold that number.
4. While holding that number press driver door lock switch (either lock or unlock) and it will beep at you.
5. Repeat process with other key and other desired position (make sure seat is in that position before)
Your position will then automatically be recalled when door is opened by person with key
Manual
