I'm just making this as a one-stop post about my personal autocross results with my CT.
So before anything, here are some FAQs I see around this topic a lot. I'll stop back periodically and update the FAQ as needed.
Keep in mind I'm making this with US viewers in mind, apologies to all you foreign folks.
-What is autocross?
A simple explanation can be found here.
-Why pick autocross?
TLDR its easy to get into. I decided to go with autocross beacuse it's quite easy to get started, literally just sign up online. I use Motorsportreg for this.
-Can I really take my CT200h to autocross?
Yes you can take the CT200h to autocross! It doesnt have to be relegated to being a tool that gets you to point A to point B.
-Do I have to upgrade anything?
Only if you want to. The CT has a few parts you can get to upgrade your racing performance. The SCCA (sports car club of america) classes the CT200h as H Street, which is the slowest class of cars. Certain mods may push you out of this class and make you less competitive.
-What mods are you using on your CT?
So far, I only have drilled and slotted brake rotors and an HKS Legamax exhaust system. Everything else is basically unmodified. I do have plans to make some custom aero mods. Other than that, some handling mods are in the works as well. I update my signature with all modifications.
-Isn't racing going to wreck my CT?
Only if it was already falling apart. If you keep up on basic maintenance and reduce the time interval between oil changes, your vehicle will not fall apart on track.
-Isn't racing expensive?
That depends on what racing you want to do. Most SCCA autocross events cost between $30 and $70 for entry, with other types of races (namely open track racing) being more expensive. You will need a helmet to race, so I would highly recommend buying your own helmet. Do note that the helmet is what makes getting into racing a little expensive. My helmet was ~$200 but its going to last for the next 10-15 years provided it doesn't get damaged.
With that all being said, this is simply a log of my personal experiences with autocross. If anyone wants to throw in suggestions/questions/comments on the topic they are welcome to do so.
Edit #1: added more FAQs
-What is autocross?
