During strong acceleration, and when maximum power is required, Lexus Hybrid Drive simultaneously uses its internal combustion engine and electric-drive motor for exceptional performance. When the electric-drive motor complements the gasoline engine, it provides higher torque, which in turn results in smoother acceleration, free from gearshift lag. With regenerative braking, the electric motor functions as a generator during coasting and braking. Energy that would normally be lost as heat is captured as electrical energy, which is then used to recharge the battery. And while traditional transmissions use fixed gears, the Electronically controlled Continuously Variable Transmission (ECVT) contains an infinite number of gear ratios to help provide optimal performance for all driving conditions. This helps improve both acceleration and fuel economy. For more information, visit the
Lexus Hybrid section on lexus.com.
