I own a 2016 Lexus CT200h with just around 40,000 miles, and I was noticing that I was averaging 23mpg when I normally average around 40mpg so I assumed that the hybrid system was not working properly. Knowing that I had gotten a warranty with it when I bought it pre-owned over a year ago, I took it back to the dealership that bought it from to ask them if they could check to see if my hybrid battery was working how it was supposed to be. They came back and told me that the battery is holding a charge, but is just draining faster than normal. I asked if this would be covered under my warranty to get a new one but they said that it is not because the battery is technically still working, just not necessarily perfectly, and the warranty only covers things that are completely broken, and not things that happen to the car overtime from basic ownership even though I don't think that this should've happened from "basic ownership". I went to a local Lexus dealership and got quoted over 4,000 dollars to replace my current battery with a new one. Now I'm left with a cars whose whole purpose is to be gas saving but now can't hold a charge. Not to mention all the weird sounds the cars makes from constantly switching from the hybrid system to the gas engine with the battery dying so frequently. Not sure if this is a common warranty issues, or my dealership just being jerks but make sure to get the details about what your warranty covers!
2015 eminent white pearl
If you were mechanically inclined you could replace the batteries with a lithium upgrade. More power and longer EV mode driving. The lithium packs are 1900. The regular ones are around 500 refurb (?). If you have to pay for someone to put it in, then nothing you can do but shop around.
2012 Lexus CT200H - 111K
Stop going to the dealership to solve your problems.
The battery in the ct200h is the same battery in the Gen3 Prius.
You have two options here:
1. Get a reconditioned battery and have it installed at a prius/hybrid car shop near you or install it by yourself. Its not that difficult. More information digging will get you there. Like I said. This vehicle shares components with Gen3 prius. Instructional video for the prius will be the same for ct200h.
2. Fix the individual cell yourself. The battery is composed of many individual cells. When one or two of the cells has an issue it affects the whole battery pack. Many people have replaced just a few battery cells and the car was back to good. Again. Like before, the ct200h has the same battery pack like prius gen3. There are plenty of instructional videos online for how to replace batterys individually.
Thanks
  • Like
Reactions: x111951753
Hold your horses
No warning dash board light?
The battery might be weak
But still alive.
Mpg problem? Look somewhere
Else.
Binding Brakes
Dirt inlet manifold
Clogged egr
Logged Air filter
