1 - 20 of 43 Posts
I'm in the process of changing out the filament lighting with LED's.
So far I changed the licence plate lights and the interior dome light.
I was able to fit a 36 SMD led in the dome light. Now when you open the door the interior is illuminated as though it is daytime.
I found it easier to remove the whole light assembly from the roof then remove the clear lens. It made it easier to mount the SMD and I would imagine easier to install the "festoon" adapter.
I have also included a pic of the variety of LED SMD's I purchased.
Next to change out will be the vanity lights and the map lights.
Did you get these thru that guy Matt recommended?
I bought them all on eBay.
The prices below are total price including shipping for the specified quantity:
36 led smd qty 1 - $3.29
12 led smd qty 2 - $5.19
9 led smd qty 3 - $8.28
Wedge qty 8 - $10.00
Festoon. qty 2 - $5.69
Overall pretty cheap plus I have some some spares !!!!!
Audi4T, the only lights I care to change would be the rear license plate bulbs...like the bright white ones that come on a Lexus GS car...is it easy to get the bulbs out? I think I saw somewhere that you have to remove some parts inside the car---not from the outside and where did you get the bulbs (and, oh yes...what size)?
Most of these have double sided tape and SMD led's generate little to NO heat!
Discussion Starter · #7 ·
The access panels for the license plate bulbs are the two innermost panels on the inside of the rear hatch. These just pop off and then you aceess the lamp holders. Unclip the connector and twist the lamp holder anti clockwise.
The led is the wedge style WB.
Many offered on eBay - inexpensive.
Discussion Starter · #10 ·
audi4t, can share some photo how you took off the interior dome light cover? I try yesterday but no able to get the cover out.
The complete dome light (frame and lens)simply pulls away from the roof lining.
Sit in the back seat and put your fingers between the dome light and the roof lining. The edge closest to the back of the car popped out easily. there are small "hooked" clips holding the complete assembly in place.
The front two can be released with the help of a screw driver.
Then you can disconnect the little box containing the festoon bulb (use a screw driver to pry the rectangular gray box from the light) and remove the whole unit.
With the unit removed you can push the clear lens out of the frame which enables you to mount the LED smd symmetrically to the frame with double sided tape. Then clip the lens and frame back together with the electrical leads and festoon connector coming out the back - ready to be clipped back into the connector hanging from the roof.
Make sure you check polarity before assembling everything. LED's are polarity sensitive and only work when the connection is correct.
I've started the replacement process... ordered some 5 LED SMD's from ebay for a few $$$'s and replaced the license plate, puddle and vanity mirror lights. Started to replace the map lights (home link panel) and ran into a problem. I tried the 5 LED SMD's both way round to confirm polarity but could not get them to light... any ideas?
Jimbo
Fixed my problem! Pins not making contact in the Map lights properly... All done now... Much happier with the look than the standard bulbs....
May I know what size is for the reverse light?
I found when I tried to replace the reverse lights, that they were very loose and actually came out while driving, so I put back the original bulbs. But everything else changed OK. (See my signature)
tming77,
Where in Malaysia are you from? I have not seen any CT in Malaysia, and my last visit was in June.
Tim
I'm from Johor Bahru, Malaysia. Is quiet difficult to spot a CT here in Malaysia. In my state, not more than 100 CT sold. Whole Malaysia only around 1000 and most of them still waiting for the shipment from Japan
1 - 20 of 43 Posts
