Lexus CT 200h LED Light Swap Courtesy of LuxuryMods.com! - Writeup for Puddle Lamps!
Swapped out my lights in my car today. Worked with Tony from LuxuryMods.com.
Tony will be putting together a kit for the CT on LuxuryMods.com.
June Gloom over here in Southern California. 0800 in the morning, 68 degrees Fahrenheit in Costa Mesa, CA. Did the LED swap in the parking lot. Approximately 45 minutes.
The CT is relatively simple compared to other Lexus models. No foot well lighting or door courtesy lights to replace.
Just two overhead map lights, one dome light, two vanity lights, two puddle lamps, one trunk light, and two license plate lights.
10 lights were exchanged total.
The lights are easily removed using a simple flathead screwdriver, so I won't go into much detail about replacing those. The hardest lights (and they weren't even that hard) to replace were the puddle lamps. Similar to the RX puddle lamps where you have to remove the mirror to get to the screws that hold the housing together.
This is a write-up for the puddle lamp LED swap.
You'll need a Phillips head screwdriver, and a 194 wedge 5SMD LED bulb.
Tilt the mirror as high as you can, then reach below it and start pulling up and out, exerting gradual pressure until the plastic clips release. As long as you exert gradual pressure, they will come off cleanly. It will take quite an amount of force. Once the two clips on the bottom release, pull outwards to release the top two clips.
Here's a picture of the passenger side mirror with the mirror off:
You'll remove 5 screws with the Phillips head screwdriver.
Then remove the rear mirror housing by pulling it straight out.
Here's a picture of the inside of the mirror housing after I've pulled it off:
Here's a rear view of the mirror with the housing removed:
You'll want to look up from the bottom of the mirror for the puddle lamp housing. I'm pointing at it in this picture:
Just pull the housing out, turn the bulb socket counterclockwise to remove it from the housing, and swap the bulb out. Make sure the polarity is correct by testing the bulb BEFORE reassembling the whole mirror housing! Just shut all the doors, lock the doors with the remote, and then unlock the car. The puddle lamp should light up!
Reassembly is the reverse of these directions. Same instructions for the other side.
The bulbs that were used for other parts of the car are as follows:
Two overhead map lights (HomeLink console):
9SMD panel x 2
In my car:
Dome light:
24SMD panel:
In my car:
Vanity lights:
3SMD Flank 194 Wedge Bulb x2:
In my car:
Trunk light:
6SMD Festoon bulb - 31mm
In my car:
License Plate lights:
3SMD Flank 194 Wedge bulb:
In my car:
Here are some pictures of the completed mods:
Please contact [email protected] if you require further information or want to purchase a set for the CT. Good luck!
UPDATE: Tony has listed the CT lighting package on his website @ LuxuryMods.com! Check it out!
9SMD panel x 2
In my car:
Dome light:
24SMD panel:
In my car:
Vanity lights:
In my car:
Trunk light:
In my car:
In my car:
