I assume you mean the headlight housings? If so then I am sure that will not work as each car is designed and molded to the shape of the housing. If you mean the headlight bulb then as long as it's an H11 bulb it will work, although I'm not sure why you would want to do that.
Yea I meant the housing. If there is any nicer looking one that will swap. Thanks for the info though
