1 - 11 of 11 Posts
Excellent... thanks for posting the pictures!
Liking that :)
Discussion Starter · #6 ·
Good catch.I believe these pics are of the first generation of this motor. We are on the 3rd version which I believe has eliminated the drive belt.
Very cool! Does anyone know what's used, if anything, to cool the electric components and electric motor? The only obvious part of the hybrid system that I found was the cooling fan for the rear battery (near rear passenger seat/door).
There is a separate cooling system with radiators for the electrics.
Check page 498 on the link below. Pay attention to number 1 and number 4 in the drawing
http://drivers.lexus.com/t3Portal/document/om/OM76004U/pdf/sec_04-03.pdf
Yeah. The actual HSD electric components in the inverter actually have channels where coolant runs through to cool the electric components. It's pretty awesome!
If I'm not mistaken, the inverter actually gets circulated coolant first because the circuits in the inverter are most likely to heat up fastest under high-load conditions. then the coolant enters the reservoir, and the pump recirculates the coolant to the engine and then back to the radiator.
There are channels and fins that circulate the coolant inside the inverter, sorta like a water-cooled heatsink.
Thanks Matt, that answers what I was looking for.
1 - 11 of 11 Posts
