From this:
To this:
Due to the influence of our fellow members, I was motivated to pursue this DIY. The parts are sourced from our local wreckers here down under.
Tools needed:
19mm socket for steering wheel nut
Phillips screwdriver
Flathead screwdriver
Prying tool
Wire Cutter
Electrical tape
Additional wires
Pigtail remover - optional
Sumitomo TS 025 Female Terminal 0.22 - 0.5mm2 (24 - 20AWG) - (this is need to instrument cluster but optional to your preference)
Before starting anything, please disconnect the 12v battery for safety measures and accidental airbag deployment. This is important.
I started with the replacement of steering wheel
1. Remove the airbag
Pop the covers located behind the steering wheel (right is at the cruise control, left is a cover). Once the covers are out, locate the three pins that holds the airbag. 1st pin can been seen easily from the bottom left side of the steering wheel and the other two is way up. Below is the Youtube link on where you can find the pins:
There are three wires connected to the airbag. Use a prying tool to pop up the yellow tabs on the black and orange connectors. The ground wire also has a notch and you can use a small flathead screwdriver or prying tool to disconnect it from the airbag.
2. Remove the 19mm nut holding the steering wheel and electrical connectors
Once the nut is removed, disconnect the black and white electrical connectors located just above the spline. Even though the nut has been removed, I observed that the steering wheel is firmly sitting on the spline. Tap the steering clockwise and counter clockwise to make it loose. You can wiggle by holding the steering wheel but be careful to avoid the clockspring being damaged.
Here's another Youtube video link that you can refer to for the entire steering wheel removal:
If you are only planning to change the steering wheel, just do everything in reverse.
Next, adding wire to the system to support the new instrument gauge using the buttons of the new steering wheel
3. Remove the instrument cluster and cover
Using a pry tool, pry the cover and disconnect the power button. Here's the Youtube link:
You can proceed to remove the entire instrument cluster if you wish to do so.
4. Remove the steering column cover
Use the Philips screwdriver to remove the screws facing you. Next, pry the covers on the left and right of top steering cover. The top cover should go first and the bottom cover can be easily removed by sliding towards to you.
5. Add additional wire to the black socket found on the bottom of the steering column
Remove the black socket
Cut the black and white wire. Note that there are two black and white wires. You will use the one located on top running no. 4 from left to right
Connect a new wire leading to the behind of the instrument cluster connector
To this:
Tools needed:
Prying tool
Wire Cutter
Electrical tape
Additional wires
