Here is a list of all the bulbs in the CT200h and which LEDs I used or will use and a quick description on installation.
This is for a 2011 CT200h.
I have installed everything except the turn signals and headlights.
If found out what the A and NA mean.
A = Amber painted glass (cheaper to make)
NA= Natural Amber glass (glass is made with the amber color)
Also, I dont think the parking light listed above even exists.
The only lights I see on the front housing of the car are the high headlight H9, low headlight H11, drl leds, side yellow marker light led, and the 7444NA turn signal. There are no other bulbs.
This was the kit I purchased from Velocity Shop: White SMD LED Interior, License Plate and Back up Lights Package Lexus CT200H 11-12
LDK-DCLB-LEX-CT200H
Qty: 1 at $29.80 .............................................. $29.80
5050 SMD LEDs
QTY 2 puddle lights on the mirrors
QTY 2 visor lights
Purchased from superbrightled: https://www.superbrightleds.com/mor...bulb-5-smd-led-wide-angle-wedge-base/206/919/
168 LED Bulb = WLED-WHP5
$5.95 ea
5050 SMD LEDs
http://www.ct200hforum.com/forum/le.../131186-install-mirror-puddle-led-lights.html
Nylon Pry Bar Installer Kit 4 Pc
Plastic Prybar Set from Harbor Freight
$5.99
(this is so you dont scratch anything while prying, also used to remove your side mirrors for the puddle lights)
Backup lights - 194 LEDs (outer lights) and License plate lights - 168 LEDs (inner lights)
1. Just pry open the 4 access hatches on the cargo door.
2. Rotate the bulb socket to the left to pull out the bulb socket. (the license plate lights have a very tight fit, may hands barely fit, if you have big basketball player hands you may not be able to read them.)
3. Install the LED bulb into the socket.
4. Check that at the bulbs work and swap their directions if needed. (the LED bulbs only work one direction due to the polarity).
5. After verifying all the LEDs work, reinsert the socket into the housing and rotate it to the right to lock it in place.
6. Reinstall the 4 access hatches.
Less than 10 minute job.
Cargo Light - 3022 LED
1. Use the plastic pry tool to pry open the housing.
2. This LED bulb is slightly longer than the original bulb. You will need to bend the tabs to get the new LED to fit properly.
3. Install the LED bulb.
4. Check that it is working. If not then reverse the bulb.
5. After verifying it works, the push the housing back into place.
Dome Light - 3022 LED
1. Use the plastic pry tool to open the dome housing at the notch. Just pry it open.
2. This bulb is a little longer so you need to bend the tabs to get the new bulb in.
3. Check the bulb works and reverse it if it does not.
4. After verifying the bulb works, push the cover back on.
Map Lights - 168 LED
1. Use the plastic pry tool to open the cover by prying from the windshield side.
2. It is hard to grip the old bulbs to remove. I wrapped a rubber charity bracelet around the bubs, tightened it, and then pulled down and the bulbs came right out. Also a rubber band would probably work to do this.
3. Install the new bulbs.
4. Verify they work and reverse the bulb if needed.
5. After verifying the work the push back on the cover.
Visor/Courtesy Lights - 168 LED
1. Use the plastic pry tool to open the cover. I pried from the left side.
2. Swap the bulbs.
3. Verify the bulb works and swap it around if needed. (for those who dont know how to turn this on, you just slide the visor mirror cover over and it switches on the light).
4. Reinstall the cover.
I bought the turn signals and when I get them I will make a new topic to install.
I could not find the parking light listed above and I dont think it actually exists. I think they just listed the front signal twice as the parking light.
Here are the only bulbs I could find:
Light | Style | LED Style | LED | Description | QTY | Install | ||
Back Up Light Bulb | 921 | 194 | WLED-xHP13-T Oversized Bulb | 194 LED Bulb - 13 SMD LED Wedge Base Tower | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs | $12.95 | LED Back Up Lights | 2 | On the rear of the car. Access by prying open the small access panel on the inside of the rear hatch. Turn left to release the housing and pull bulb straight out. |
Brake Light Bulb | LED | X | ||||||
Center High Mount Stop Light Bulb | LED | X | ||||||
Courtesy Light Bulb | 175 | 168 | WLED-xHP5 | Search Results For "168" | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs | $5.95 | LED Visor Light | 2 | Above sun visors inside car. Use plastic pry tool to remove lens from one side. |
Mirror Puddle Light Bulb | ? | 168 | WLED-xHP5 | Search Results For "168" | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs | $5.95 | LED Mirror Puddle Light | 2 | Remove mirror with plastic pry tool. Remove 5 screws to open housing. Twist bulb to the left to remove old bulb. |
Daytime Running Light Bulb | LED | X | ||||||
Dome Light Bulb | DE3175 | 3022 | 3022-xHP4 | Search Results For "de3175" | LED Products | Super Bright LEDs | $6.95 | LED Dome Light | 1 | Above passenger seat. Use plastic pry tool to pry open from the two notches towards the front/engine side of the car. Pull bulb from one side to tilt it out. |
Fog Light Bulb | H11 | 2011 CT200h: Fog Lamp - LED - New from the latest 2014 model builds, the Lexus fog lamp feature a Light Emitting Diode (LED), which use less energy while providing a dramatic styling element and most importantly makes your Lexus more visible to other | $137 | Fog Light | 2 | In bumber behind the wheel well liner. | ||
High Beam Headlight Bulb | H9 | |||||||
Low Beam Headlight Bulb | H11 | H11 | CREE - XML2 chip 2400lm 20W | 40W 2400x2 LM 6000K H4 H L H7 H11 CREE XML Chip Car LED Head Light Fog Lamp DRL | eBay | $75.99 Set of 2 | 2 | ||
License Light Bulb | 168 | 168 | WLED-xHP5 | Search Results For "168" | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs | $5.95 | LED License Plate Lights | 2 | On the rear of the car. Access by prying open the small access panel on the inside of the rear hatch. Turn left to release the housing and pull bulb straight out. |
Map Light Bulb | 168 | 168 | WLED-xHP5 | Search Results For "168" | LED Replacement Bulbs for Cars | 12v | Super Bright LEDs | $5.95 | LED Front Map Lights | 2 | Above rearview mirror. Use plastic pry tool to pry open from the seam towards the front/engine side of the car. Light pulls straight down. |
Parking Light Bulb *I dont think this exists. | 7444NA NA= Natural Amber Glass | 7443 | 7443-A45-T Amber | https://www.superbrightleds.com/mor...led-16mm-wedge-base-7443-tower-bulb/634/2081/ I dont actually think this bulb exists, I cant find any other bulbs on my CT200h. It may be that this is also the front turn signal and they just listed it twice for some strange reason. | $24.95 | ? | ||
Rear Side Marker Light Bulb | LED | X | ||||||
Tail Light Bulb | LED | X | ||||||
Trunk or Cargo Area Light | DE3022 | 3022 | 3022-xHP4 | Search Results For "de3175" | LED Products | Super Bright LEDs | $6.95 | LED Cargo Light | 1 | Side panel in the rear cargo area. Pull bulb from one side to tilt it out. |
Rear Turn Signal Light Bulb | 7440A A=Painted Amber Glass | 7044 | 7440-A45-T Amber | https://www.superbrightleds.com/mor...5hp-led-16mm-wedge-base-7440-tower-bulb/1013/ | 24.95 | ? | 2 | |
Front Turn Signal Light Bulb | 7444NA NA= Natural Amber Glass | 7443 | 7443-A45-T Amber | https://www.superbrightleds.com/mor...led-16mm-wedge-base-7443-tower-bulb/634/2081/ | $24.95 | ? | 2 |
LDK-DCLB-LEX-CT200H
5050 SMD LEDs
QTY 2 visor lights
$5.95 ea
5050 SMD LEDs
$5.99
2. Swap the bulbs.
