I have replaced 12 volt battery with new one but after changing the battery, Hybrid System Check light is appearing and engine does not started. Before changing the battery engine worked fine. Does anybody knows what is the problem and how can I fix it?
2015 eminent white pearl
Blown fuse, fried inverter, dead key battery... May seem like a simple problem but we don't know what exactly happened.
What made you change the battery? Did someone try to jump start it before you replaced the battery? Perhaps let it sit overnight and try in the morning.
Obd scanner is needed
