1 - 1 of 1 Posts
Well you could get a certain gadget that checks the individual cells. You put the car in neutral and run the air conditioner with the parking break on. It drains the battery as the neutral state prevents the engine from charging the battery. Then it tells you exactly which cells need replaced. The whole battery doesn't fail at once. And since it is the same battery as a prius you could save a fortune at a toyota dealership if you go that route.
1 - 1 of 1 Posts
