My CT200h has a premium sound system, and has a speaker(subwoofer?) at the trunk. How can I remove its cover/grill? I guess I can detach it without any tools or remove other parts, but I'm worry I damage it. If someone has a picture of the speaker cover which shows clips of cover edges/or gives me an instruction, I will appreciate it.
It just pulls back but it is glued on with these protruding pins, you will need clean old glue and reglue it for it to sit right
My car was used though, so who knows if someone already tried pulling it off and just broke it and glued it back on...
Just curious, why are you trying to remove the cover? It is possible to replace the speaker with a better one (there is a writeup on this site somewhere) but it's quite a bit of work. It certainly isn't just "plug-and-play" due to the small clearances and weak amp.
