I don't think so, it was designed that way. Have you tried wrapping the key in aluminum foil....maybe it will block the signal?
The other idea, you can hide your key on top of one of the wheels (assuming nobody see you do it)!
I don't think so, it was designed that way. Have you tried wrapping the key in aluminum foil....maybe it will block the signal?I was wondering whether there is a way to leave the remote in the car and only take the key with me. I want to avoid that the remote gets damaged when swimming in the ocean.
My attempts to leave the remote at the weirdest places In the car didn't work. the doors wouldn't stay locked.
thanks in advance fro your help
That's something I haven't heard before. I use the loop on the end to hang my keys, so no taking the key out for me.I took the key out to lighten the weight of the remote - since I always have the remote in my pocket - made a difference!!
Hi TomsterdudeI put the key in a small water proof bag in my wet suit and had no problems.
Yes, I just tried this. Aluminum foil does block the key signal (as does a metal canister).I don't think so, it was designed that way. Have you tried wrapping the key in aluminum foil....maybe it will block the signal?
The best solution by far, thanks for sharing! My previous car was without key detection and I never had issues while going to surf. I'm glad that at least one workaround is there, wouldn't want to stay puzzled by the oceanI am a triathlete and often do open water swims. I took the key out of the remote, put the remote in the glove compartment, locked the glove compartment with my key and then locked the car doors with the key manually. I put the key in a small water proof bag in my wet suit and had no problems.
