21 - 40 of 115 Posts
H11SU SilverStar Ultra
Doing this voids any warranties?
Yes
Here is a solution <albeit not as good> that still fulfills warranties, which is apparently very important to you because you have asked in several threads:
Yes
Interesting. What I have heard in other discussions on this matter in other forums is that if you end up with a symptom on your car and bring it to the dealer, they can only say the mod caused the problem if they are able to prove it.
I did not think that it would void your warranty all together, is that what you are saying? :confused:
I'm really sorry but I gotta say something here....geez live a little...first of all it's your car. Don't live like everything is gonna break, for god's sake! Second, if ALL ( and I do mean ALL) else fails I can undo this mod in less than 15 minutes. BUT...I don't want to and I won't. I put the HID's on 'cause I like the look and I don't spend time "looking back". The phrase "JUST DO IT" comes to mind...
(Steps off soapbox, returns to below radar status);)
my philips HID kit 4200K
off topic ... just for sharing
my dark window tinted
the 1st CTh gathering in Malaysia
How do you like the Philips kit? I was contemplating that one, but because there was only a 2-year warranty, I went with the DDM tuning one with lifetime warranty.
Were the ballasts small enough to mount?
I only dare to use Philips kit, not dare to use any of the cheap china make HID. If i go to the cheap China make, i only need to pay MYR200, but this Philips cost me MYR1400. Very happy with color and brightness.
Wow, that's a big price difference for you!
I finally contacted DDM Tuning (after waiting on hold for a while) and asked them for a warranty claim request, my drivers side ballast won't fire up the bulb all the time and it's getting annoying. And at times it's embarassing that I'm driving around in such a nice car that's only 2 months old and at times, only 1 light works.... :mad:
Sucky part is they won't send me a new one until I send back the old one!? WTF!
:( WTF? I hope it gets resolved promptly.
Ddm is off the list with that kind of service
Can post pix where u mount the hid ballast?? I am thinking change to phillips but the ballasts look kinda big
Discussion Starter #35 (Edited)
I think this issue would be resolved by installing the relay harness and providing a direct 12 volt feed to the ballast rather than via the existing headlight wiring. Also have you have tried switching ballasts between lights to eliminate either the ballast or the bulb?
Is it the drivers side headlight giving you the problem?
Funny you mention that, he told me to diagnose it first, before returning it to him. I am going to swap the two bulbs from side to side, as that's easier than swapping out the ballasts. I want to confirm that it's the ballast that's the issue and not the bulb.
Yes, it IS the drivers side, why do you ask????
I asked him about the size of the ballasts and mounting of same earlier/above and he didn't respond.
Discussion Starter #38
I think the issue is with voltage drop in the wiring harness feeding the drivers side headlight. If u simply change the bulb and the drivers side still doesn't ignite u still have to eliminate the ballast feeding the drivers side bulb. All the problems on my wife's car were on the drivers side and only when the lights came on with the auto feature not with a manual turn on. I bought the relay harness and when I get time I'm going to install that. I'm certain that will eliminate the problem.
Where do you guys buy the relay harness, is it plug and play for most HID kit in the market? Thanks.
Ahhh, okay. Well I went to quickly change out the 2 bulbs after work today just before dark, but I forgot/didn't realize I can't unplug them from the ballasts without taking out the coolant tank, so I'll just swap the 2 ballasts and give that a try.
FYI - I never use the auto headlight feature and my issue is not 100% of the time, but the majority of the time, when manually turning them on.
