Hi Buddies,
I am planning to change the low beam to HID, any recommend brand?
And I heard some ballasts cannot work with auto turn on function, driver side light will not turn on when putting at auto light. Anybody know this issue?
Should I purchase a computer warning canceller & Anti Flicker?
Thanks.
Moderator
I run a standard DDM kit and I have no issue with flickering or auto function.
Just installed the xenondepot.com extreme hid kit in the low beams (4300k Philips) and fogs (3000k). Install was simple plug and play, did not use the fused relays. Auto feature works perfectly. Just have to adjust the aim on the low beam and fogs.
Kinda old but I just read a thread about them having hot spots after installing HIDs? Possible fix issue is to go with HID projectors. Are you seeing any hot spots yet?
Moderator
Yeah, there are some hotspots, but overall, it's a huge improvement over using halogens without having to crack open the housings.
