I recently lowered my cut on Megan racing springs I have always lowered vehicles with no trouble but my drivers rear clunks over bumps. I have check everything I took loose and tightened it but it seems my noise I can feel at the top of the strut but it dosnt seem loose. Any help would be appreciated.
With the rear of the car jacked up do the springs still have preload on them? If they feel even slightly loose that will cause the noise. This is the reason you see preload springs (a thin spring) in addition to the main spring on many coil overs like KW's.
Discussion Starter #5
I noticed today after taking it apart the noise comes from where the strut threaded part goes through the top shock cover and I can't figure out why it's rubbing
