Hello fellow CT owners, I am new here and tried searching but could not find an answer to figuring out where I can find out the size of the holes found in both the engine front/covers and also the bumper bottoms.
I found this part online
Details about LEXUS OEM FACTORY ENGINE COVER CLIPS (Qty 10) 90467-07211
but I want to know the size of the rivet diameter in millimeters in order to order a cheaper alternative and in bigger quantity if possible.
I was hoping someone here might know the size of the rivet/hole.
I ordered some 8mm which were quite big, and I have been eyeing 6mm rivets, but I want to confirm before purchasing and wasting more time and money.
Thanks in advance.
Thanks in advance.
Hi i had the
same issue while removing the cover .so I bought assortment of clips from AliExpress.
It cost really cheap.
It will serve you for other missing clips
