Hello everyone :)
Is there a way to fix this minor damage?
Currently, there is no issue with the headlight it works perfectly, but I'm afraid that in long use the headlight might start not working as it should.
Thanks,
Photo of the crack:
Automotive lighting Automotive tire Hood Grille Motor vehicle
Lexus CT200h 2011
Hello, you can buy a new headlight cover and replace the cracked one:
Or you can put some transparent silicone sealant to prevent water or moisture from getting into the light.
· Super Moderator
That is purely cosmetic and threatens nothing on the car. There is no way to fix it other than to replace it as suggested above by Zed. However, there is no problem to just leave it like that. That is not the seal, the seal is deeper. You can see it is just to help keep the head light and fender aligned. But the rest of the lens is intact, so it will stay aligned.
