Greetings. I'm in the process of swapping my halogen headlamps on my 2013 to the OEM LED option.
I purchased some used ones from reputable ebay sellers. One didn't come with the ballast, so I found one model number 85967-47020. The other already has a ballast, but it is much different, 85967-30070. Is there going to be an issue running these two?
I believe there has to be a harness made or fabricated to make the proper connections.
Any help would be appreciated, thank you.
Interesting to switch to the OEM LEDs. I will say the aftermarket ones have advanced to the point they are pretty darn good. And for $40 on Ebay. No balast, plug and play. Just mention it if you didn't get your OEM ones to work.
