I recently blew the fuse for the cigarette lighter / power. Where is the fuse located?
Lower left near where drivers feet are. Check page 542 of the (2011) owners manual. Section 4.3 -Do it Yourself Maintenance. 15 amp fuse... Mind sharing what caused the overload?
I was using an air pump to inflate my bicycle tires. I think the constant on and off may of blew the fuse
Ok.. must draw a bit to much current even though it has a power socket plug. Was there a spare 15 amp fuse in that fuse box? I didn't see and extra one in the fuse box under the hood.
In a pinch you can use the 15A fuse from slot 32 on the driver side fuse box.
This is designated as PWR OUTLET 2 but it is not being use.
(see attached image)
