if you have a non-navi Ct200h then you are stuck with 1 USB port.
I bought this splitter from amazon (not affiliate with seller) Amazon.com: Cute USB Mini 2-Port USB 2.0 Hub Splitter (Black): Computers & Accessories
and was able to split the USB port
I keep one tiny 16GB usb stick to play music, while i can use the 2nd one to charge my phone.
you have to plug the usb stick in first then plug the phone. otherwise it will show an error when you have both usb device active.
However if you wish to play music form the phone you would have to remove the usb stick.
you can also now charge 2 phones on the go now.
it also does not block the AUX in, which is a plus.
Cheers,
