I'm having bad mold smell from my 2011 ct200h AC. I'm looking forward to use the AC foam refresher kit but I'm unable to locate the evaporator plug.
Some says behind right front tire (when tire turned left), while some points to under engine cover. Can someone please confirm evaporator plug exact location ?
Thanks in advance.
Sent from my SM-N910V using Tapatalk
Discussion Starter #2
Never-mind, I figured out the evaporator drain plug location and alternative way to clean it . I cleaned the drain line, which was causing the smell. Now - after cleaning - there is no smell at all. I created video too for reference .....
